Ring End Gap Question
Sodbuster
02-17-2005 16:44:19
Have a new hydraulic lift cylinder, rings and piston. Rings are standard rings. Specs call for a ring end gap of .003-.008. No more than .008. With rings 2in. in cyl., they measure .010. Am I missing something here or what? T0-30 tractor....
Gerald J.
02-18-2005 10:52:45
 Re: Ring End Gap Question in reply to Sodbuster, 02-17-2005 16:44:19
The cylinder bore is worn. Maybe as much as .007 / 3.14159. Might need oversize rings, but the bore may need to be opened up so its not barrel shaped. Check the ring gap all through the travel and see how much its barrel shaped.
Gerald J.
Sodbuster
02-18-2005 13:38:10
 Re: Ring End Gap Question in reply to Gerald J., 02-18-2005 10:52:45
All parts are new, cylinder, piston and rings. Never used. Just received them from Davis Tractor yesterday. All part#'s match up to tractor. I know that rings will expand with heat but, I don't know if they will expand that much..... .....
Gerald J
02-18-2005 17:40:30
 Re: Ring End Gap Question in reply to Sodbuster, 02-18-2005 13:38:10
If the shop manual calls for .003 to .008 and you have .010 with new parts, either the rings or cylinder or both are out of tolerance. Its likely that the .003 minimum is to allow that much for ring expansion with heat.
Gerald J.
Sodbuster
02-18-2005 18:33:27
 Re: Ring End Gap Question in reply to Gerald J, 02-18-2005 17:40:30
That's my way of thinking as well. Measured the new cylinder bore and it is correct. I guess I will soon know, one way or the other. The old rings in the old cylinder measured .026. It was leaking like a faucet but, believe it or not, the lift had plenty of lift to it. Things work backwards here in S.C.. Thanks for the info....
Gerald J.
02-19-2005 07:06:21
 Re: Ring End Gap Question in reply to Sodbuster, 02-18-2005 18:33:27
With multiple rings, be sure the gaps are as far from being aligned as possible to lengthen the path way for the oil leaking through the gaps.
Gerald J.
