how many amps ??
gshadel
02-17-2005 06:21:03
Hey guys, any idea how many amps I can load on my original TO20 generator and still keep a charge on my battery. I'm thinking of adding some more lights to my TO to really light-up the night.
I have two front lights now, would like to add two rears, and I'm thinking of making a "light bar" across the front with several lights on it. thanks
mike2
02-17-2005 17:57:51
 Re: how many amps ?? in reply to gshadel, 02-17-2005 06:21:03
Well, theoretically, if the generator you are utilizing will output 11 amps @ normal operating conditions, then you have a total of 66 watts available for use. This is assuming you are operating on the origional 6 volt system since you mentioned the generator and not an alternator. However, keep in mind that if you utilize the full 66 theoretical wattage available, you will not recharge your battery. If you exceed the 66 watts, you will draw from both your sources of power and eventually completley discharge the battery. If you use less than 66 watts you will successfully operate your load and recharge you battery. The recharging will be directly proportional to the total consumed watts. On a final note the 66 watt value is not just for lights, but is for the entire electrical system. Therefore, you will have to determine the normal watts consumed by the ignition system and associated components before a final value is known for "spare" watts.
Hope this helps and does not overwelm you.
Jim W
02-17-2005 11:15:21
Being a TEA/Lucas type, I don't know the exact answer but I am willing to bet it's "not many". The Lucas genny output a whopping 11 amps, which will recharge your battery - in a while.
I'd replace it with something with higher output, possibly an alternator. Making brackets and getting pulleys that fit is that hardest part.
In my own case I found a 19 amp Lucas generator that I was able to fit without too much hassle.
Jim
