Question for Zane or John(UK)
Sodbuster
02-15-2005 16:53:02
What is a "air lock in side chambers in the pump?" What would cause it, how would the lift act and what would be the remedy? I am reassembling my pump, don't know if I will be faced with this or not. Cannot find any literature on this subject, at least not in the ferguson manual..... ...I have a TO-30.
John UK
02-16-2005 09:45:59
 Re: Question for Zane or John(UK) in reply to Sodbuster, 02-15-2005 16:53:02
An air lock is very unusual as we said in that earlier posting but it can happen. It is when the pump can't draw the oil through for some reason and consequently can't push any oil through the side chambers and valves to start off the hydraulic process.If this happens, they advised slackening off the top vertical setscrew on each side chamber (one at a time) and bleeding off any air that may be in there and allowing the oil to get into the chamber and valves, once it does that it will usually work, barring any mis-assembly of the valves as Zane rightly said.
Sodbuster
02-17-2005 09:10:18
 Re: Question for Zane or John(UK) in reply to John UK, 02-16-2005 09:45:59
Thanks John, you've been a big help.
John (UK)
02-17-2005 12:30:58
 Re: Question for Zane or John(UK) in reply to Sodbuster, 02-17-2005 09:10:18
U R W anytime
