TO20 Rear Axel Shims
T B
02-14-2005 18:49:19
I just replaced the SureSeals on my TO20.I had the local MF dealer replace the seals. After beating on them till blue in the face, I gave up. They went through 3 different types of seals before they found one that actually fits around the sweat collar instead of over it. Anyway, I'm getting ready to reassemble and am trying to figure out the process of shim'ing the axels. There is some movement of the hub/axel in and out. When installing shims till the opposite wheel no longer turns, should the slop in the axels be pushed in while obtaining clearance, pulled out, or do I have other problems? The book isn't much help other than to add shims to get clearance.
Any help appreciated.
Thanks, Tom B.
John UK
02-16-2005 10:06:26
 Re: TO20 Rear Axel Shims in reply to T B, 02-14-2005 18:49:19
You add shims till the opposite side stops turning the add a further .008" - .010" to get correct end float. To check it you have to tighten up all the bolts each time till the setting is correct. And don't forget to use new gaskets on the brake backplate.
danct
02-15-2005 10:21:39
TB
go to posting on 1/25/05.and read Phil(va)answer,its the information you are looking for,ive used it myself
Danny
T B
02-15-2005 16:40:04
 Re: TO20 Rear Axel Shims in reply to danct, 02-15-2005 10:21:39
Thanks, after reading the thread I have a better understanding
Tom B
