Sure seal pictures
Jim W
02-07-2005 09:25:43
Thanks to Paul Thiucke of Wisconsin for sending me a bunch of pictures showing how he replaced sure seals on his TO20.
I made a web page about it since the topic comes up here so often. I would like to know if what is shown there applies equally to the TEA series, as I cannot recall off hand, so if anyone knows please advise and I will update the site accordingly.
Thanks,
Jim
Gene Stevens
02-08-2005 04:39:49
 Re: Sure seal pictures in reply to Jim W, 02-07-2005 09:25:43
Jim, can you e-mail me the pictures? Web site would not let me in. e-mail [email protected]
Thanks
Gene
Jim W
02-08-2005 12:53:51
 Re: Sure seal pictures in reply to Gene Stevens, 02-08-2005 04:39:49
Hi Gene,
Try again, sometimes it only lets in so much traffic at once.
Seems to be working pretty well now, but if you still have a problem get back to me.
Jim
Dale in Mn
02-08-2005 04:32:14
I have a question to. Will they also fit a 59 TO-35 and a 61 MF-35?
Neal
02-07-2005 22:48:52
Question: Is the rear end on the TO30 ths same as the TO20? Will sure seals work om TO30?
John (UK)
02-09-2005 07:41:39
 Re: Sure seal pictures in reply to Neal, 02-07-2005 22:48:52
The TO30 most already have the second seal fitted, the Sure seal is for the tractors without this second seal. If your axle seals are leaking and they have the two seals already fitted you will have to have the axle-shaft pulled down and new seals and possibly bearings fitted. Are you sure it is the seals anyway and not just the gasket worn away because the nuts have been slack allowing it to move.Have you actually looked where the leak is coming from, can you see the seals leaking or have you taken it that because there is a leak it must be the seals, it's not always them.
Little Dave
02-07-2005 23:04:54
Neal the TO-30 has an inter and outer seal and is different that the TO-20. Dave
John (UK)
02-07-2005 16:42:52
Hi Jim, Yes pretty certain they are the same and looking at your pics I am even more convinced they are. I know the Sure seal fits the TE series
Jim W
02-07-2005 09:26:54
Whoops the link title got truncated somehow.
gshadel
02-07-2005 10:51:03
 Re: Sure seal pictures in reply to Jim W, 02-07-2005 09:26:54
Jim, just checked out your webpages. They are awesome! Keep up the good work ! I've been threatening to tear into my axle seals, I know they leak, and my brakes only work on one side. With the pic's from Paul and your explainations... I'm more inclined to tear into mine and install new seals.... maybe this weekend!
