Adjusting the control spring
Normand Richard
02-06-2005 19:11:05
Hi,
I have a H.F. TO-30, which the hydraulic lift control spring needs to be adjusted. I have the shop manual for my tractor, but it doesn't go into detail as how to adjust the yoke. Would someone kindly provide me with a detailed step-by-step procedure.
Thanks,
Norm
John (UK)
02-07-2005 16:35:14
 Re: Adjusting the control spring in reply to Normand Richard, 02-06-2005 19:11:05
if you email me at fergusontractors at tiscali dot co dot uk I will send you detailed instructions on what to do and how to do it...John
Paul in Ms
02-07-2005 04:12:26
Place a plow or some other piece on the three point hitch and lift off the ground. The control spring should just be able to turn with your hand if not adjust by turning the yoke in or out. Sounds easy but if yours is like mine the threads on the shaft and yoke was rusted tight. With heat and patience it finally came loose. Only after I pulled the linkage from the control valve.
