radiator?for my to30
digg,nc
02-03-2005 18:55:51
is leaking a tiny bit at the top and was wandering how you can fix them without buying a new one and another question the top radiator hose hooks to a removable part on top of engine mine has a crack in it at the bolt,im not wanting to fix this part want a new one ,this part will unbolt from engine and i noticed the gas tank is bolted to it to, Where can i get this top piece and what is the proper name of it ?i have a continetal z 129 engine
Jerry/MT
02-03-2005 19:51:34
 Re: radiator?for my to30 in reply to digg,nc, 02-03-2005 18:55:51
The correct name for the coolant outlet is "Elbow, Water Outlet" part # 181635 M1 and it is common to the TO-20,-30 and the TE-20. have you tried the parts folks on the left? or a MF dealer?
If the radiator is leaking at the point where the tank mets the core, you might be able to solder it. If it's leaking in the core, sometimes squeezing it closed with needle nose pliers works. And then there is always Barrs Stop Leak.
