If it ain't broke... don't fix it
gshadel
02-03-2005 14:15:05
If you have a pretty good 6V system, no reason to spend the big money and time to convert to 12 volt. Spend a few dollars to make sure your battery cables are stout and fat, and your connections are clean and strong, your 6 volts should start on the coldest Winter day.
Most the posts I see concerning charging problems are from people that have a 12 volt conversion that ain't working right.
But, 12 Volt system has a couple advantages too, it lets you run 12V equipment, like lights, horns, sprayer pumps, etc. which are easier to find than 6V equipment. I've been looking for a good old fashioned 6 volt OOOGAH horn , can't find them, I see 12 volt horns all the time! And the other guys are right, your starter will turn faster on 12V.
I'm not a 6 volt purist, when I got my TO-20 about 6 years ago, I decided if the generator ever died, I'd go ahead and convert to 12 volt then. Still waiting for that to happen.
Bill WI
02-04-2005 15:20:41
 Re: If it ain't broke... don't fix it in reply to gshadel, 02-03-2005 14:15:05
I agree with you fellas. My TO 30 is the easiest starting tractor I ever had --IF --it turns over. After putting a new sleeve set in it got a little bauky. Put a set of brushes and bushings in the starter motor and couldn't ask for more. I put them in myself so less than $20. I use this tractor around the place and no matter how cold away she goes. Maybe I'm lucky lol
