TE serial number
Reg Cornelius
02-02-2005 22:06:24
The plate on dash is missing the eng number is S99166E Want to no what year of mfg and serial no if possible
leslie leek
02-06-2005 13:56:09
 Re: TE serial number22782 in reply to Reg Cornelius, 02-02-2005 22:06:24
the date on the diff case is 21 2 46 it has no external oil filter itis tvo the engine number isz120a600 a could you tell the month itwas assembled and how many was produced
John (UK)
02-09-2005 08:35:42
 Re: TE serial number 22782 in reply to leslie leek, 02-06-2005 13:56:09
Well you got the date the casting was made,But it was made in 1948, the first tractor that year was number 20895 and they made almost 57,000 tractors that year. The problem is that you don't know when that engine was actually used, they didn't use the engines in any particular order, so it could have been fitted at any time although I wouldn't have thought it would have been hanging around too long. Just to make matters more difficult, around September 1947 they started fitting the Standard engine as well so the serial numbers were rising but with no details of the dates when the engines were fitted so you have two different models of engine with one series of serial numbers for the tractors. They were making about 600 a week at that time, so its highly likely that your tractor was made in the first month. I have just been checking the master list from the factory and it shows that your tractor has an engine numbered Z120 A600 FB27, the first tractor produced in 1948 was 20895 the next tractor we have a date recorded for was number TEA27137 on the 23rd March 1948 so you should be able to get some idea of just when it was made. I think that is a close as we can get unless someone else comes up with a serial number with a definite date.
George Drexel
02-04-2005 15:53:11
 T0 serial number in reply to Reg Cornelius, 02-02-2005 22:06:24
I can't tell what I have. Please someone help. The serial number is: T0-56352
I can't find it in any list. It's a Harry Ferguson.
John (UK)
02-05-2005 06:11:56
 Re: T0 serial number in reply to George Drexel, 02-04-2005 15:53:11
TO56352 = 1951 TO20
John (UK)
02-05-2005 09:12:07
 Re: T0 serial number in reply to John (UK), 02-05-2005 06:11:56
George, Just been thinking about that number you sent just now....where did you get it from...as it could be a part number and in that case it could be a totally wrong date I have given you. Did you find that cast into the steering column mounting/ I think I have had that one before.
George Drexel
02-05-2005 08:04:24
Thanks a million.
Jim W
02-03-2005 04:45:54
 Re: TE serial number in reply to Reg Cornelius, 02-02-2005 22:06:24
Looks like serial number would be about 170,400, built in 1951, if the chart on this page is close. (Note it is compiled from owner's input so there could be cases of engines having been replaced etc.)
You can also check for a date code cast into the left side of the differential housing, just ahead of the dipstick.
Jim
Reg Cornelius
02-03-2005 22:30:49
 Re: TE serial number in reply to Jim W, 02-03-2005 04:45:54
think it is a TEA 24 Date on diff housing 8.12.0
Vince
02-03-2005 03:36:33
in 1949
all the TE from the 77773 to the 116 461!
you can visit this page !
http://www.fofh.co.uk/tech/dates.htm
Jeff-oh
02-03-2005 09:16:47
 Re: TE serial number in reply to Vince, 02-03-2005 03:36:33
No dis-respect Vince, But you provided the tractor SN info and he already stated that the tractor SN plate was missing.
Are you sure it is a TE, and not a TEA or TO??? You can tell
