Massey Ferguson 165
Walter
01-31-2005 05:13:36
I am having problems witht he hydraulics on my 165. It is a 1973 model witht he perkins deisel. It will no longer lift the attachments off the ground. I have been doing some research and it seems there might be filter that often gets clogged??? I am looking for any hints, suggestions, and or other ideas on what to do. Has anyone else had this problem? What did you have to do?
Thanks
lonestarjeff
02-02-2005 13:54:56
 Re: Massey Ferguson 165 in reply to Walter, 01-31-2005 05:13:36
Big Dean on the MH-MF forum is the real expert. He directed me on a similar problem last year w/ my 165. One thing, though, my position control lever did not work but the draft lever would still lift & drop the implement.
He told me a hard knock on the rear linkage(like ramming a round bale)can knock the internal lift cover linkage out of adjustment. He was right.
Jeff
Jeff-oh
01-31-2005 05:58:18
There is a filter on the hydraulic pump. It can be accessed from the left side inspection plate. The procedure to dis-assemble and clean is in the MF-126 Maitenence manual. If you do not have one I would suggest you get one. They are available form this site. (very 1st link on the top left of this web page)
Jeff
Walter
01-31-2005 06:19:19
 Re: Massey Ferguson 165 in reply to Jeff-oh, 01-31-2005 05:58:18
Thanks Jeff, I'll see about ording it. Have you had this problem before? Does it sound like it could be clogged filter or maybe a pump gone bad? I just want to start witht he easiest solution and work from there. Any other ideas you can think of? Thanks... I'll take any suggestions I can get.
Jeff-oh
02-02-2005 05:38:29
 Re: Massey Ferguson 165 in reply to Walter, 01-31-2005 06:19:19
No I have not had that problem. My MF-65 was one of the 1st and does not have the filter you talk about. the filter came out in mid-production.
Jeff-oh
02-02-2005 05:38:30
ric
01-31-2005 18:06:32
you will probably get alot more input in the mf discussion board . just a thought hope it helps
