TEA20 TIMMING
RICHARD BRIGGS
04-20-2000 14:10:37
NOT HAVEING ANY LUCK TIMMING UP THIS TRACTOR. IPUT #1 PISTON UP ON COMPRESSION LINED UP FLYWHEEL TOPDEAD CENTER. TURNED CAM TILL ROTER WAS ON #1 DISTUBERTER CAP .PUT TIMING CHAIN ON. TRYED NO LUCK CHECKED POINTS CLEANED GOOD SPARK RESET GOOD SPARK AT PLUGS ALSO CHECKED GAS PUT IN FRESH IDON`T EVEN GET A BACK FIRE. I JUSTED HAD CRANK TURNED AND NEW BEARINGS ;TIMING CHAIN AND GEARS AND OIL PUMP.
Paul
04-22-2000 14:54:44
 Re: TEA20 TIMMING in reply to RICHARD BRIGGS, 04-20-2000 14:10:37
Richard - your timing might be off by 180 degrees. Try turning over the engine until #1 is at the next compression stroke, then line up your distributor and try again.
Paul
