axle shaft play
hank n' tx
01-24-2005 16:16:28
i took my axle shafts off my to 30 to a tractor mechanic to have the bearing and seal repalced. i dont have a press nor a torch to heat the collar. anyway there is about 1/4 inch play between the bearing housing and the hub. i feel that is to much and took it back to the mechanic and he said that it would be ok after i bolted it back up and shimmed it. but i think the bearing needs to go farther into the cone plus the collar because just putting the axle half way back together looks as if the collar will hit the seal and the axle will move back and forth about a 1/4 inch. the mechanic is a reputable mechanic and works on a lot of tractors. maybe im not looking at it right. what do you think? thanks hank
John (UK)
01-27-2005 11:46:26
 Re: axle shaft play in reply to hank n' tx, 01-24-2005 16:16:28
From the point at which it stops turning the opposite shaft in the same direction you should add shims to the thickness of .010" to give it necessary end float. Providing the bearing is right down on the shaft and the collar is right up to the bearing it should be ok, they dont go up solid there is some play in it till you assemble it into the tractor. If the bearing is not fitted correctly you will find that you cant tighten up the axle in the tractor as the bearing is in wrong position.
phil(va)
01-25-2005 07:58:16
Try this. After you get both in, with both rear wheels jacked up, turn one wheel. The other wheel should rotate the opposite direction. If it goes same direction, the axles need to be shimmed as they are too tight. If the other wheel does not turn, they are too loose.
Little Dave
01-24-2005 18:13:14
Hank there will be end play in the axle till you put both in. The ends of the axles run together to push the bearings outward. If you have both in and tight that is where you check for end play and find out if you need to add or remove shims. Little Dave
