TO 30 regulator question
Pop234
01-21-2005 15:28:41
I just got a new 6 volt regulator for a TO 30. How do I polarize it? Thanks
Duner Wi
01-22-2005 11:15:51
 Re: TO 30 regulator question in reply to Pop234, 01-21-2005 15:28:41
This info from the Dealer shop manual for TO30 and assumes system is 6 volt positive Gr. Delco-Remy system. "Momentarily connect a jumper lead between the armature terminal of the generator and negative terminal of the battery". Connect for a second should do the trick.
John (UK)
01-22-2005 06:43:18
You dont polarise it, its a generator that you would polarise if anything. The regulator should work if you connect it up, if it doesnt it is something else, maybe the generator.
ooooo
01-25-2005 15:49:15
 Re: TO 30 regulator question in reply to John (UK), 01-22-2005 06:43:18
if you remove the wires from the generator posts
do you have to re-polorize the generator? thanks in advance, denny
