tea-20 distributor
danatpei
01-17-2005 04:27:54
just got dist. rebuilt put it on tractor and worked fine but noticed , when it was running distributor was moving a bit, it was good and tight wondering if there should be a shim or gasket where it mounts to the two studs, was none when i took it apart. cost a bit to get it done so don,t want to run her until i get it figured out. any info. would be appreciated thanks.
John (UK)
01-17-2005 14:25:05
 Re: tea-20 distributor in reply to danatpei, 01-17-2005 04:27:54
If it is tight it shouldn't move, check if the flange is distorted and not perfectly flat. It needs to be flat to be be tight and not move.
Al in BC
01-17-2005 08:51:55
Good day Sir.
To my knowledge there is a gasket under the distributor adapter. The old part number was 825-662-M1.
If you measure the gap with the nuts pulled down, then produce a gasket of slightly thinker compound you should be in the money and Harry should run for anothere 50 or so.
Hope that helps.
Al in BC
