rusty gas tank TO20
Mike Griffin
01-14-2005 12:39:59
I have a HF TO-20 with a lot of rust in it. Removed the tank and there is a baffle wall inside, does anyone have any ideas on how to remove the rust as there is no space for a ball bearing to get to that side of the tank. Thanks for your help.
Greg Warren
01-19-2005 18:21:14
 Re: rusty gas tank TO20 in reply to Mike Griffin, 01-14-2005 12:39:59
John,
I had the same problem with my TO30. I took the tank to a radiator shop and they did an acid flush and relined the tank. Cost $75.00 and it took two days. Good as new, clean gas and as clear as water.
danct
01-14-2005 13:04:45
mike
i used a product called POR15, and it worked great for me ,you have 3 steps to follow but if you follow the directions it will fix your problem,i tried the chains and the bolts and a few omy own remidies but the tank i had was in bad shape,,i called 877-548-9323 and asked for enough to do a 10 gal tank they will send you what you need ,i think around $50 bucks for all but a bit of work for you also
Good luck
Danny
scott6143
01-15-2005 18:12:08
 Re: rusty gas tank TO20 in reply to danct, 01-14-2005 13:04:45
Mike
I agree with Danny, i used POR15 on my to20 not only did it take care of the rust it fixed the pinholes too!! Also had a little sealer left and did the outside of the tank also, paint will stick to the sealer also. 3 yrs, no rust, no leaks!!!
John (UK)
01-15-2005 13:09:41
If all else fails it is possible to get a new gas tank for these tractors.
