Thrust Washer
Hillbilly
01-12-2005 13:10:57
I am replacing the thrust washer on my TO-30 The pins that it sets on are damaged any one have a trick for getting them out of the block.Thanks
Jim Polanosky
01-13-2005 14:02:40
 Re: Thrust Washer in reply to Hillbilly, 01-12-2005 13:10:57
Hillbilly;
I just did my Z129 and had the same problem with the Thrust Washer. I used a Dremel tool with a cutoff disc and cut the pins to get a flat surface; then carefully center-punched them & drilled them out. Start with a smaller drill and 'sneak up' on the sizes!
I then re-drilled the holes in the block with a #29 drill and tapped the holes 8-32. I got some brass flat-head screws and turned the heads down slightly to reduce the diameter. I then used a countersink tool and countersunk the (3) pin holes in the new Thrust Washer so that the new screws would fit slightly below the surface of the washer, then installed the whole thing using Threadlocker loctite.
If you're still looking for crankshaft shims, email me your address & I'll send you some - I had to put another crankshaft in my z129, so I ended up with some spares.
Good Luck!
