drawbar questions
gshadel
01-04-2005 12:50:25
I'm thinking of getting into the local antique tractor pull this year, looks like fun. I also want to pull a 5' X 10' trailer around the yard and give hay rides. What kind of drawbar do I need on my TO-20 for all that? Is the swinging drawbar kit I see on this site what I need? Does that swinging drawbar work by itself, or does it need the drawbar with all the holes that runs between the two lift arms and the stays, like I see on N's sometimes?
thanks
Boss Hog
01-05-2005 05:03:27
 Re: drawbar questions in reply to gshadel, 01-04-2005 12:50:25
I tried a tractor pull once. The max drawbar height was 19", which was much higher than the swinging drawbar. So I used the drawbar that goes between the lift arms, with the braces that go up by the top link thing.
That way you can adjust the braces so as to get the maximum drawbar height that"s allowed.
pamikey
01-04-2005 19:16:14
Use the swinging drawbar to safely pull any kind of weight. I have a drawbar for the lift arms but have never used it. I've been told that you can damage the arms and they can lift in certain circumstances.
Jerry/MT
01-04-2005 14:34:14
I have both types of drawbars;the one that's mounted to the bottom of the tractor and has a hole/pivot pin drawbar attachment and the type that mounts to the 3 pt hitch arms. I was always told to pull wagons & trailers by the bottom mounted drawbar. I looked in my Ferguson parts manual and to use the 3 pt mounted drawbar, your supposed to have a whole crap load of stuff to stabilize the hitch. If it was me, I'd pull on the bottom mounted one, but I haven't analyzed the situation from a load standpoint so I wouldn't go to the bank with that. Maybe someone who pulls can give you that info.
John (UK)
01-06-2005 13:31:46
 Re: drawbar questions in reply to Jerry/MT, 01-04-2005 14:34:14
If its a heavy trailer its better to use a drawbar thats slung underneath, if its just normal medium to light work you can safely use the drawbar with the stays to the top link connection on a TO20 or 30 if its a TO35 they have to go on the long hinged pin...You dont need all that other ironwork that is sometimes shown with this drawbar its very good but not really practical for everyday use.
steveormary
01-04-2005 20:32:45
We always used the cross drawbar with the arms from the drawbar pins to where the top link fastened.
Then we had to lock the draft control lever in the down position. That way we could use the pto if we had to and not hurt the hydraulic system.
We pulled a 1 row cornpicker this way and several different types of manure spreaders. Never no problems with the hydraulics.
steveormary
