TO30 won't lift implement
Ted in Wyoming
01-03-2005 10:03:03
I've got a TO30 that although the lift arms do operate up/dwn, it won't lift an implement. I don't see any turbulence in the oil or spray when viewed thru the inspection covers. I can't see a filter or screen anywhere (?). My next step was to pull the pump to inspect it on the bench for a bad relief valve or control valve, etc. It looks like the PTO shaft has to come out to remove the pump, however, after draining the oil, pulling the lift cover and removing the pto end bearing retainer bolts, the pto shaft assy only withdraws about 1" before binding up. I tried gently persuading with an impact hammer but don't want to damage anything and am hesitant to use more force in case I missed something. If I'm headed in the wrong direction, any tips on the right approach would be appreciated.
Thanks,
Ted in Wyoming.
ZANE
01-07-2005 09:52:21
 Re: TO30 won't lift implement in reply to Ted in Wyoming, 01-03-2005 10:03:03
See the link below for some items you might want for the lift.
If you will look up toward the top of this page you will see where I posted my trouble shooting guide for the lift.
Zane
farmallman
01-04-2005 15:47:13
Just curious. Is Wyoming the town in Ontario, Canada or the state in the USA? Thanks
Ray,IN
01-03-2005 20:16:40
The relief valve may be replaced without even draining the oil if you don't mind getting messy. The valve is just below the PTO shaft on the rear of the pump, and may be removed with a stubby open end wrench. PTO shaft removal can be stubborn because of wear patterns on the splines, rust and corrosion on the splines, or in the worst case senario the shaft can get twisted by abuse or hitting a solid object with a brushcutter. A twisted shaft is obvious upon inspection and is thankfully rare. I have used a small log chain to snap out PTO shafts when they seem stuck. You know, rather like snapping out a pickup rear axle. At the cheap price be sure to install a new PTO oil seal when you're ready to reassemble it. The TO series tractors do not use a hyd oil filter, just be sure to drain all three areas of the settlings and gunk before adding new 80/90wt straight mineral oil.
John (UK)
01-04-2005 11:07:18
 Re: TO30 won't lift implement in reply to Ray,IN, 01-03-2005 20:16:40
I have a Fault finding sheet for this hydraulic system, if you need it email me at fergusontractors at hotmail dot com.
Ted in Wyoming
01-06-2005 16:50:55
 Re: TO30 won't lift implement in reply to John (UK), 01-04-2005 11:07:18
Thanks guys for your responses and toubleshootting information... It was a big help!
with best regards,
Ted
