response to the two previous posts
George in NW Mi
01-01-2005 15:43:33
Thanks for both very useful responses.
The oil galley and line to the gauge look very clean....not even a hint of blockage there.
I will try the air pressure technique first. I do have garage where I can remove the pan if necessary. I did think that having an oil pump fail was very unusual.
Also, in this case, the gauge showed no pressure after it had been running a few minutes showing pressure....so doesn't that suggest that this is not a problem of getting the pump primed?
A blockage I guess is possible. This is an old tractor that has never been rebuilt and there must be a lot of sludge in there. Could the filter itself be blocked?
Fred Martin
01-05-2005 13:32:36
 Re: response to the two previous posts in reply to George in NW Michigan, 01-01-2005 15:43:33
George...I once bought a truck that didn't have any oil pressure. Found out after playing with it for a while that the spring in the ignition switch was bad and it wasn't returning the switch to where it should...move it back by hand and viola! Oil pressure! Once Had a tractor that I bought and changed the oil...checked all the things you check and started it up...ran fine, kinda extra sweet...but when I walked around and looked at the oil pressure gauge...it said zero. The engine ran good so it had to have pressure, so, I reached in my pocket for a small crescent wrench and smacked the dash (underneath) and viola again...oil pressure. The old guage just got tired in that case...have you checked yours??? Fred OH
Jerry/MT
01-01-2005 19:09:19
The oil pump is located onthe #1 main bearing cap at the front of the engine. If the main gallery is clean, I would suspect the oil pick up tube to the pump. It could be loose or cracked. When the oil viscosity is high, it may pick up oil but as it warms and thins it could lose its prime or you may have hit a bump and dislodged it because it is loose. Drop the pan and give a good look to the screen and the pickup tube and work your way to the oil pump.Look for a crack or a loose joit ora missing o-ring. It'll only cost you some time and a gasket. As the other guy said, it the filter is plugged, it's downstream of the oil sense line so it would tend to raise the presssure.
Gerald J.
01-01-2005 17:17:12
The filter is a bypass filter so plugging it raise the pressure. But it could be a sticky pressure regulator piston that stuck open and is bypassing all the oil. I've not had it out of my Continental Z-134 so I can't say where to go look, but its probably under a big hex plug on one side of the block.
Gerald J.
01-02-2005 05:55:13
 Thanks for help in reply to Gerald J., 01-01-2005 17:17:12
Thanks gents for your help. It is very cold and snowy up here now so I will wait til the weather is better, and then try all your suggestions.
Thanks again!
