Tachometer
Jake H
12-29-2004 09:26:04
when i was given my tractor i immediately started the disassembly process and restoration. when i got to the genereator i discovered that there was no gear on the generator shaft to drive the tachometer cable. besides that the tach had been busted for a long time and was used for a nice little lynch pin holder, but i want a tach...any ideas what i could do?
Happy New Years!
Jake H
John (UK)
12-29-2004 14:53:18
 Re: Tachometer in reply to Jake H, 12-29-2004 09:26:04
If it was driven off the rear of the generator then you should be able to get the drive from some repairer of generators as a spare part, but some tacho's were driven off a spring loaded wheel that was fastened to the generator and ran on the back of the drive belt, so dont know which type yours is. For me the best type is driven straight from rear of generator.
Jake H
12-30-2004 07:36:39
 Re: Tachometer in reply to John (UK), 12-29-2004 14:53:18
mine ran straight off of the generator shaft and the smaller gear from the generator drove the bigger gear that the tach drive hooked into via a small square hole.
