help!!!
Jake H
12-23-2004 16:08:36
anybody got an idea on how to remove drag link ends? also, how do you go about removing those pesky spindle bushings?
Merry Christmas!
MIKE IN PA
12-31-2004 19:35:01
 Re: help!!! in reply to Jake H, 12-23-2004 16:08:36
JAKE , JOHN IS RIGHT , I'VE NEVER HAD TO USE MORE THAN A GOOD HAMMER ON THE END OF THE ARM TO POP A TIE ROD OUT OF ANYTHING . AN OLD FARMER TAUGHT ME A TRICK FOR SEPARATING TWO PIECES OF METAL AFTER YEARS OF BEING TOGETHER . DOESN'T MATTER WHAT THEY ARE ( A BUSHING IN A CASTING , OR A GEAR ON A SHAFT ) HEAT THE CASTING ENOUGH TO MELT PERAFIN WAX ( A TOILET SEAL WORKS ) BETWEEN . JUST LET IT FLOW LIKE SOLDER . LET IT COOL AND PUSH THE BUSHING OUT ( OR PULL THE GEAR OR PULLY OFF )IT WORKS ON BULDOZER GEARS AND STACK PULLY'S ON SMALL ENGINES EQUALLY AS WELL . GOOD LUCK
John (UK)
12-28-2004 10:51:10
To remove drag link ends all you do is remove the nut and hit the lever smartly with a hammer no need for crowbars or levers or anything, hit it and it will pop out. I did it for a living for long enough to know it works.If it doesnt pop out you haven"t hit it hard enough...it won"t break.
Ed in MD
12-27-2004 06:30:24
One of the above should work for you and I would like to add one thing and that is to clean the bushing area with gasoline to get all of the old grease off and then soak it really good with penetrating oil. I like to use "Blaster" it can be bought at Home Depot but there are a great many other brands and you can find them easily at any hardware or automotive supply store for a couple of bucks. Let it soak over night and no mater which method you use (beat it out or press it out)the penetrating oil will make it slide out easier. Try to find "Blaster" though, the stuff really is amazing and it will help you avoid heating it up.
Also if you can find a piece of brass rod stock to use as a drift to beat it out as opposed to a cold chisle you"ll avoid tearing any thing up.
Let us know how you made out.
Ed
Mike Mohrhauser
12-26-2004 19:22:14
Just did the bushings in my TO-20.I used a 1/4" cold chisel and hammer. To start, go easy around the outside edge of the bushing till you find the seam in it. Then beat the chisel down to the bottom of the bushing. It should pop out without too much extra force. I used a brake hone to re-size the new bushings that I put in. It will take a while but at least I didn't have to take them to the machine shop for resizing.
I'll have to try that trick on the drag link end myself.
Mike M.
Mr Chapp
12-26-2004 15:27:08
Hi Jake ... Read closley and think about it. The voice of experience is telling you the easy way. Hammers, chisels etc... Don't despair. Happy hoildays! Good luck, have fun!!! Mike
Jake H
12-26-2004 09:18:14
any easier ways...I"m only a teenager and i have limited resources...
thansk for all this info!
Machine works
12-25-2004 17:05:36
I had to use a cape chisel to drive my spindle bushings out. Its rounded on the outside edge to get a little more bite on the bushing lip.
Thomas
12-24-2004 08:32:47
Place a large bar over the track rod and under a convenient point on the tractor such that you can get push it down with one arm to lever the tie rod downwards. I have a 5' bar for this job. While applying as much downward pressure as possible, belt the steering arm head on with a hammer, as heavy as possible to give a fast blow (if that make any sense, ie with a big hammer you can't get enough speed, with a small hammer not enough weight). You're hitting on the end of the arm, in the direction of the spindle. The joint should just pop off after a few blows. Sometimes heat is necessary, but should be avoided as it both melts the joint and softens the arm.
To remove the spindle bushes, get a very small gas axe, heat on the edge of the bush till the brass is green, and blow inwards, making a cut right down the bush. Repeat this in three places, the bush can then be prized out by folding it up, usually it will colapse easily and fall apart. Wear gloves when doing the bottom ones, the grease is hot when it runs down and hits you! You need to ream the new bushes to 1 1/4". Often the spindle is also worn, in which case weld up and turn down. This is worth doing anyway as they're often bent.
Jim W
12-23-2004 20:45:38
Two hand sledges. Hit the two sides of the eye simultanously, and the end will pop out. Sometimes it takes a few whacks.
Since adopting this technique I might have removed 30 drag link ends/tie rod ends; haven't used a puller since. Note though you are unlikely to be able to do it with framing hammers; you need some mass.
Not sure about spindle bushings though.
Jim
Ol Chief
12-26-2004 02:22:21
 Re: help!!! in reply to Jim W, 12-23-2004 20:45:38
Try dry ice to shrink them out.
