TO-30 Steering box seals
Technoid
12-23-2004 15:37:15
Does anyone know where I can purchase new seals for the steering arms on a 1954 TO-30? Mine are leaking a bit to much.
Technoid
12-30-2004 14:38:19
 Re: TO-30 Steering box seals in reply to Technoid, 12-23-2004 15:37:15
Thanks guys. I found a guy who sells the seals.
The web site is Jackssmallengines.com. He carrys MF parts.
BOB UK
12-30-2004 07:07:38
Just replaced the seals on my 1949 TED only to be told afterwards that I should not have botherd but to have drained the oil out and refilled the box with grease, it made sence after all the work it took to get the steering box off.
BOB UK
England
Mike Mohrhauser
12-25-2004 06:16:20
Most of the time, if the seals are leaking it's because the outer steering bushings are in need of replacement too. I rebuilt mine in my TO-30 a few years ago. I was able to get the parts at my local MF dealer. Most times the inner bushing will not need replacing.If you plan to overhaul it would be wise to have an IT shop manual.It will have good pictures and instructions to get you through it. It's not highly technical.
Mike M.
Al in BC
12-24-2004 14:07:15
For what it's worth. I have a TEA 20-85 and I think the steering box is the same. I think that a Chicago Rawhide seal will so the job.. Seal #13027. You don't have to dismantle the box if you take a small grinder and grind off the protusions on the curve of the drop arms. The protusions with the center hole in for spinning in the lathe. Be careful not to shower the rest of the tractor with dust. You will be able to slide the old deal off and on without any problem. Remember a little grease on the seal to make it slide better.
Just a thought. Merry Chrismas to all.
Al in BC
Brent, IN
12-24-2004 12:53:23
These are still available from the MF dealers. Part #195 761 M1 according to my old parts book. I checked on this about a month ago as I also need new seals and they were listed as available. About $5 a piece I think.
Jerry/MT
12-23-2004 16:05:38
Have you tried the folks on the left of this forum? How about an MF dealer? Do a search in this forum and also a google search.
