are TO20's prone to crack blocks?
Jim Nauert
12-16-2004 18:38:04
I have been trying to sell my TO20 and had a guy contact me to look at it. When i emailed him to confirm his comming on sat. he informed me that TO20's have a 90% chance of having a cracked block and probably already has one. Someone must have fed him this info i thought they were a rugged tractor with a stong motor. Am i wrong?
Richard neuharth
12-21-2004 16:47:04
 Re: are TO20's prone to crack blocks? in reply to Jim Nauert, 12-16-2004 18:38:04
My dad had a TO-20 We used it on a farm when I was younger for many years, we used it total for about 25-30 years almost daily , never had to rebuild it except for cleaning a radiator which anyone could do. A very strong versitile tractor. The block was fine and we could pull a 2 bottem 2-16 plow on occasion and a 20 foot disk harrow in 3rd gear. Like the previous person said, block cracking is due to neglect and after 20-30 years you just have to do a reasonable compression check and see if the tractor you want is up to snuff or realize it may need attention.
steve19438
12-19-2004 09:52:46
i would say about 30 to 40 percent of to-20, 30 and 35 blocks are cracked and it is not just from overheating, freezing causes it too. (low anti-freeze level)
if you want to do a simple test on your block drain the cooling system and fill it with a 50/50 solution of anti-freeze and water. run the engine till it reaches operating temp. and then check for oil in radiator or crankcase. if you have oil in radiator only the block is cracked at the top, if it has anti-freeze in crankcase you have cracks at the bottom of the block.
Jerry/MT
12-19-2004 19:52:23
 Re: are TO20's prone to crack blocks? in reply to steve19438, 12-19-2004 09:52:46
Wouldn't have the same symptoms with a blown/leaking head gasket?
Sivert
12-17-2004 20:31:35
I have a TO20 that my Dad got in 1964 and just rebuilt the engine. I had the block checked and it was perfect. We worked it in the concrete business for years along with a TO30, I rebuilt it in 80, same thing, it has the same block, they have never had a problem with a cracked block. We worked them very hard to. I have newer tractors but love my little fergie, the TO20. They never made a better all around tractor, well I like to believe that. Now it launches boats and does the gardening and all the fun stuff. Can't get the price you want, keep it!!!
MichaelNEIowa
12-17-2004 19:07:46
If he is so sure that 90 percent of TO30's have cracked blocks, then why does he want to buy one? I question the buyer's logic.
Sodbuster
12-17-2004 15:37:05
Don't let him "con" you. Trying to soften you up for the kill. Stick to your "guns"..... .....
Jerry/MT
12-17-2004 09:23:07
I don't know where the potential buyer got his statisitics from but I doubt that the real numbers are as high as 90%. These Continental blocks were prone to crack if they were overheated but if the cracking were serious, they's be water in the crankcase in copius ammounts(I don't mean a little condensate). Of course that could happen with a blown head gasket,too. Remanufactured blocks are furnaced brazed to fix the cracks and if the process is done right and followed up with the appropriate machining, the block is as good and maybe better than new. I say better because the furnace brazing process stress relieves the block. If a block is cracked, a remanufactured one is about $500 (the block only). Make the buyer prove to you that the block is cracked before you discount your price.
heath glenn
12-06-2005 15:09:33
 Re: are TO20's prone to crack blocks? in reply to Jerry/MT, 12-17-2004 09:23:07
where can you find a remanufactured block for a to20
Jim Nauert
12-17-2004 11:42:21
Jerry, I no for sure that my block is not bad. This guy just said it was sight unseen. If i cant get what i want for it i will just keep it it's a good handy tractor.Thanks to all for your input.
marlowe
12-16-2004 19:46:23
they did if you over heat them and most at one time have been over heated NOT the tractors falt just owners that don't take care of things. i have three to-20s ALL are OEM and NO cracked blocks that i know of
steveormary
12-17-2004 09:20:16
 Re: are TO20's prone to crack blocks? in reply to marlowe, 12-16-2004 19:46:23
Jim
We ran a TE-20 for about 10 years and a TO-30 for 50 years and never crack the block on either one. We didnt run them hard but would work them at a steady pace. What is the history of your TO-20.How long have you had it.
steveormary
Jim Nauert
12-17-2004 14:36:24
 Re: are TO20's prone to crack blocks? in reply to steveormary, 12-17-2004 09:20:16
I have had it for 3 years the guy i bought it from had it 30years his uncle had it befor that. I have had no trouble with it they used it to do a little farming small scale. After that they used it to plow snow that is what i used it for. I also hauled wood, and did a little disking with it.
Ryan
12-18-2004 13:49:15
 Re: are TO20's prone to crack blocks? in reply to Jim Nauert, 12-17-2004 14:36:24
When we overhauled my gradfathers t030 it had cracks between the cylinders but we put it back together and use it almost every day, that was ten or more years ago. We are not plowing with it or working it hard, just mixing concrete and using the hitch on the front.
Ryan
Ray,IN
12-17-2004 20:29:09
The Conteniental engines are very reliable, fuel thrifty, and durable. The reason for a cracked block is overheating due to owner/operator neglect. The radiator fins must be cleaned often when brushogging, or performing dirty, dusty work. The entire cooling system must be serviced every year at a minimum to prevent or reduce corrosion and coolant flow restrictions. I would ask this prospective buyer why he is interested in a tractor he is sure has this large a problem in his mind. He sounds like a skinner to me.
