No oil pressure today...what could be wrong?
George in NW Mi
12-16-2004 09:07:46
I started up the TO-20 today to plow some snow. After running for a few minutes, I noticed the gauge showed no pressure. It always showed 20 psi before.
It was not knocking and I wondered if the gauge had failed...is that probable?
The oil in the pan did not feel very warm after running which made me suspect it was not circulating.
Might the oil pump have failed? How hard are they to change?
Thanks
Jerry/MT
12-16-2004 14:10:58
 Re: No oil pressure today...what could be wrong? in reply to George in NW Mich, 12-16-2004 09:07:46
If you didn't have any oil circulation, your valve train would have been audibly noisy and the mains and rod bearings would be pounding and clicking respectively. You didn't say that was the case.
It's possible some condensate could have frozen in the oil pressure gauge sense line (you said you were going to plow snow) or the gauge might have failed. If you can get it into a warm place try it again after it has a chance to warm up. You can disconnect the sense line as gshadel suggests. If it is clogged, try heating it gently with a propane torch or a heat gun, but be careful.
George in NW MI
12-17-2004 06:34:52
 thanks for suggestions, about the main bearings in reply to Jerry/MT, 12-16-2004 14:10:58
Thanks for suggestions. I will check out the line to see if it is plugged. There is, and has been, some clicking in the valve train. When it has gotten low on oil, this has been worse.
But it sounded like it usually does when I saw there was no oil pressure showing on the gauge.
As for the main bearing sound, there was none. However, I recently had a catastrophic oil loss on my Dodge van. I lost all the oil and drove it home carefully, about 10 miles but coasting with the engine off much of the way. Anyway, what was surprising was that there was no sound from the mains. There must be enough oil in there to last longer than you might expect.
Also, I have seen cars run without oil until they seize (at car shows etc)...and they seize before there is a real sound of mains failure.
gshadel
12-16-2004 10:59:18
George in Mich., this is George in Ohio.
Gauges can fail, it might just be a clog in the capillary tubing running from the block to the gauge. 1st thing to do might be pulling the cap. tube at the block to see if it is clear. If you think the port is clear, start your engine for a few seconds, you should get a small mess of oil from that port if your pump is pumping.
If it is the pump... a sudden failure might just be a stuck-open relief valve, which is in the pump, or a bad seal on the suction tube between the oil pan and pump.
The pump is easy to pull, once you drop the oil pan. The pump is bolted to the front crankshaft bearing cap. Pump rebuild kits are fairly cheap and easy to get. I don't recall the torque to re-install those crank bearing bolts, if you go that route, send us another post and we can get you the torque numbers.
