TEA Generator, Need More Power
Petrer(Ottawa)
12-13-2004 06:11:48
I installed a 6 1/2 foot truck plow with eletric over hydraulics onto the front of my TEA. Loaded the tires , installed chains , this thing works great. The only issue is that it kills my new battery every time . I cleaned all connections , ran all new heavy wires to the plow. I also measured the generators output and it's approx. 13 volts.
What can I do ????? Thanks , Peter
Jim W
12-13-2004 07:56:52
 Re: TEA Generator, Need More Power in reply to Petrer(Ottawa), 12-13-2004 06:11:48
The generators on these are only rated at 11 amps which recharge your battery if you have a hard time starting, eventually...
Two solutions: alternator, or higher output generator.
Alternator: one-wire versions make for easy wiring, more fooling around with physical mounting, sticks out beside the hood so gets a bit of weather, once done, reliable.
Generator: I put one from a TR3 on mine and still had to fool a bit with mounting, but not bad. Regulator should be compatible; lucky me, I had one around.
Either way you go it would be hard to find a replacement that would not do the job, current wise.
I have some details on my website; check under Electrical in the table of contents.
tractorfix
12-13-2004 18:19:06
 Re: TEA Generator, Need More Power in reply to Jim W, 12-13-2004 07:56:52
Ihave a TEA with a Chrysler alternator and regulator, and I have TEA and Super Dexta with one wire Chev alternators. They work great. Bright lights, easy cranking. The trick on a TEA is getting an alt with the wide pulley. A electric rebuilder should have no trouble supplying it.
cstbob
12-14-2004 07:10:53
 Re: TEA Generator, Need More Power in reply to tractorfix, 12-13-2004 18:19:06
tractorfix is right. An alt. is the way to go. You will never generate enough power for a regular elect/Hydralic plow set up. You need a big amp. altenator and as big a battery as you can fit in.
