TED20 oil pressure
Doctor Peter (U
12-05-2004 01:36:31
Now that the colder weather has arrived, I am a bit alarmed about the oil pressure guage reading nearly 100 psi after engine start-up and then gradually going down to around 10-15 psi after about 5 mins. Does this mean the pressure release valve needs attention? Could any damage be done meanwhile?
Appreciate any help
John (UK)
12-05-2004 06:05:25
 Re: TED20 oil pressure in reply to Doctor Peter (UK), 12-05-2004 01:36:31
It sounds as though you do have some bearing wear from the pressure reading you have given but it will be ok for now. Have you got the correct grade of oil in the engine? Should be SAE 40 in UK. A multi-grade oil may help if the engine is in fair condition (20W/50)
