TEA disributor
Ian A.
11-29-2004 21:13:58
i was removing my disributor because the pin on the end but i had to remove the the whole tube off the side of the tractor and when i pulle the pise off the big gear that rund the oil pump and the distributor it pulle it up off the oil pump shaft and the key fell off i found the key and now i cand figure out how to get the gear back onnto the shaft with the key i thought about super gluing the key in the shaft its a 1951 tea-20
Ian A.
11-29-2004 21:16:43
 Re: TEA disributor in reply to Ian A., 11-29-2004 21:13:58
sorry about the misspelling it was dark and couldnt see the keyboard
Jim W
11-30-2004 08:59:17
 Re: TEA disributor in reply to Ian A., 11-29-2004 21:16:43
Pull the shaft up that the gear goes onto. It has a tab on the end that fits into a slot on the oil pump. Put the gear with key back onto the shaft, then lower them down so the gear engages with the cam. It's tricky because you have to anticipate how much the teeth will cause the gear and shaft to rotate to have you ending up in the right place. If you try it enough times you'll get it but you do need patience.
You can relocate the oil pump position using the shaft so things line up. It is important to get the gear engaged in the right spot with your cam as this sets your ignition timing. However, it is possible to miss by a tooth or so, then rotate the distributor to make up for it.
Jim
