Lift system oil? slow lift
Chris Kehoe
04-09-2000 13:19:28
my lift has always seemed slow to me. In Nov. I changed the fluid with 80/90 gear oil?? was that right? The old fluid was almost brown. The lift is still slow especially in the cold. Is there a lower viscosity I can use or should I use a magnet heater on the differential.
sam hale
04-17-2000 06:39:48
 Re: lift system oil? slow lift in reply to Chris Kehoe, 04-09-2000 13:19:28
You must never use that oil!! it will dammage the pump and ram. the reason for it being slow is because the pump is knackered out!!!!! !!
Chris Kehoe
04-23-2000 22:33:30
 Re: Re: lift system oil? slow lift in reply to sam hale, 04-17-2000 06:39:48
What should I be using?
I do not know what was in there before, and it was slow before it was changed.
Any suggestions on what to do now?
teadave
04-09-2000 19:22:25
go to the n board and type hydraulic oil in the search. get ready for some reading
teadave
