Polorizing generator TO 35
Dean Logan OH
11-24-2004 06:51:20
Guys, I know this has been on here 100's of time buy refresh my memory. My 35 is a 57 gaser. Is my gen internal or external ground ? How can I tell ?
James, UK
11-24-2004 10:48:55
 Re: Polorizing generator TO 35 in reply to Dean Logan OH, 11-24-2004 06:51:20
Easy enough, start the engine, run it up to +/- 1000 rpm, with field and thick 'D' lead disconnected. With a voltmeter between the field coils and ground, you should see roughly 1.5 to 0.9 volts - the polarity of this, with respect to the chassis, will tell you whether you have positive or negative ground, and you also miss out the blue sparks bit, which is a good thing.
If you do the same test, with the D and Field tabs connected, you should see about 2.5 Amps between the connected tabs and ground - a good test to see if your generator is working well.
HTH
