trans/hyd oil - 80-90 wt.?
rusty nut
11-20-2004 17:01:59
is gl1 80 90 wt? in stores i see trans/hyd oil 20wt,i thought it is suppose to be 80-90 wt for TO30, the 20 wt i see does not say gl1 it says trans/hyd oil.the m1103 costs to much at masey ferguson dealer,$20.00 for 2 gallons.
Jeff-oh
11-22-2004 05:21:52
 Re: trans/hyd oil - 80-90 wt.? in reply to rusty nut, 11-20-2004 17:01:59
The trans-hydrolic oil you see in the stores is not the GL-1 mineral oil recommended in the manuals. It is a thinner oil. What you want is Massey oil spec. 1103. This can be hard to find but is available. Some report that massy spec. 1129A (permatran III) is acceptable in the winter. As the heaver stuff is too thick below 50 degrees.
The Gl-1 Mineral oil is available at NAPA as PN 65-205. 5 gallons ~$27.00. (i.e. 37.5 lbs pail)
GL-1 is also available from a shell oil distrubitor under the brand name Dentax.
Hope this helps.
marlowe
11-20-2004 19:23:27
GL-1 will come in all weights but for your 30 you need 80-90
Dave in CA
11-20-2004 17:26:11
You can get GL1 at NAPA auto parts stores for $26.00 to $29.00 for 5 gallon pail.
