distributor
Ian A.
11-20-2004 16:46:15
i was checking the timing on my tractor today it started running and then stopped checked the rotor and now its not turning i would like to know how to take the disributor on a tea-20 and where can i get a new gear and/or shaft
John (UK)
11-21-2004 09:37:59
 Re: distributor in reply to Ian A., 11-20-2004 16:46:15
It may just have sheared the drive pin through the drive gear.
Ian A.
11-21-2004 10:37:29
 Re: distributor in reply to John (UK), 11-21-2004 09:37:59
i am preaty sure that i sriped the gear because before this happened there was more than 1/4 tur of play in the rotor besides the centrifugal advance and how do you take the disributor out is it a matter of just un bolting it and pulling it out or is there more to it if it pin sheared would the gear fall off while pulling it out an john(uk) could you please send me the directions on how to set the timing and how to ajust the top linkage in the rear this is all for a 1951 tea-20 my e-mail is [email protected]
John (UK)
11-21-2004 11:21:39
 Re: distributor in reply to Ian A., 11-21-2004 10:37:29
I sent you the directions for timing and the Hydraulics set-up yesterday Ian, let me know if you dont get them please and I will send them again. Just unfasten the clamp at the bottom and pull it out. if the pinion has sheared it will stay in there. I have the spec for the distributor springs if you need them.
