TEA20 TIMING?
RICHARD BRIGGS
04-09-2000 05:07:00
I.AM STILL NOT HAVEING ANY LUCK WITH MY TEA20 STILL TRYING TO GET IT IN TIME. NEED HELP!! BOGGER.
Greg Chalmers
04-09-2000 19:37:54
 Re: TEA20 TIMING? in reply to RICHARD BRIGGS, 04-09-2000 05:07:00
You have to find the timing marks first. Contrary to any material I have read on TEA20's the timing marks on mine are located as follows. Remove the starter, about 1" under the starter is a hole approx 3/8" round. Turn the crank until you see a single 3/8" hole on the flywheel. Line up these two holes (a phillips screwdriver through the two holes) This is top dead centre. Set your rotor to plug #1. I advanced my timing slightly from there but that is where I started.
RICHARD BRIGGS
04-12-2000 16:00:33
 Re: Re: TEA20 TIMING? in reply to Greg Chalmers, 04-09-2000 19:37:54
GREG. THANKS FOR THE IMFORMATION.ON TIMING JUST BEN TO COLD 20`S. AND BIZZY AT WORK .WHEN I GET A DAY OFF AND WARMER WEATHER.IWILL GET BACK AT IT. THE BOGGER. AT S.L.U. UNIVERSITY. THANKS.
