TE20 oil pressure
Gary Mac
11-18-2004 10:49:09
What is normal OP w/z120 eng? Changed oil and went from 10-15 psi to 30+. Is screen in pan necessary?
Gary Mac
11-22-2004 12:56:46
 Re: TE20 oil pressure in reply to Gary Mac, 11-18-2004 10:49:09
Thanks for the help guys.
Gary
Sam-Ga
11-22-2004 12:45:27
Gary:On my TE-20 the can was upside down and had been that way for a long time.(no or very little oil pressure) I turned the can over put in a new filter did not put the strainer bach in (it was in bad shape). now it has 30 lbs oil pressure and sounds much better
gshadel
11-18-2004 12:48:55
What the other guys said is all good. Most guys would be thrilled to have 30 PSI with 30 wt oil, there are a lot of Z-120's running around just fine with 10-15 PSI too. I recommend keeping that oil strainer, your oil pump, and some of the oil ports have pretty small clearances, if your engine drops a chunk of crud or piece of metal, it may shear the oil pump gear or plug an oil port. It's just my opinion, but I think the oil filter does a mediocre job at best, most the oil bypasses the filter anyway. I don't think it would be the end of the world to run a while without a filter, but with the strainer....never tried it though...
Good luck!
John (UK)
11-20-2004 08:46:57
 Re: TE20 oil pressure in reply to gshadel, 11-18-2004 12:48:55
ANY filtration is better than none
txblu
11-18-2004 11:46:32
Viscosity of old and what you put in could be the reason too, besides the old being dirty. Higher the vis, higher the press for a given set of circumstances.
Mark
Jeff-oh
11-18-2004 11:29:47
30 psi is good at engine start-up. May drop to 20 psi after warm and that is fine too.
Jeff.
