I mow with a 6ft trailed mower - on steep hills it is less trouble (balance wise) than a mounted one like a bush hog or finger mower. Worst hill I do is 1st gear straight up, and 1st gear straight down, feet off everything (clutch, brake etc) and you need about 20 yards of flat run out. Fitted a folding ROPS last year - its OK except when mowing under low trees(!) so now I have learned to look up, forward, back and sideways simultaneously . . . . . . I feel like a nodding dog in a car window. If the suction between you and the seat gets too high for your personal comfort level, slow down, throttle back, and plan a safe route out. Above all do not panic. Others on here have commented on mowing sideways on hills whilst sitting on the topmost edge of the seat - with wheels at full extension with no problem. Personally I do not think it is worth the risk. Buy a couple of goats instead :) Someone once told me that if you are traversing a hill and the back end starts to slip that it is a natural reaction to turn 'uphill' which is the worst thing to do, as it makes the angles worse - apparently you must remember to turn downhill. Don't know, never tried it, never want to. HTH
