12 volt conversion
Gary/OH
11-17-2004 13:16:57
I switch my TO-30 over to 12 volts and broke my
starter.What can i do to keep this from happening again It was the original 6 volt starter.
Rod in Smiths Falls, ON,
11-21-2004 16:49:40
 Re: 12 volt conversion in reply to Gary/OH, 11-17-2004 13:16:57
My Chrysler M47 marine engine was converted to 12V negative ground about 12 years ago with no problems whatever. My advisor told me to put a resistor on the distributor, make sure I don't hook the poles up backwards (it was a 6V positive ground), and NEVER run the starter for longer than 15 seconds at a time.
The old girl's engine hardly ever spins for more than one second to start. She's way more reliable now, so that I can shut off and drift whenever I want without dropping the hook.
PD
11-19-2004 20:24:41
As has already been said thousands of times before....a 6-volt electrical system in good condition works just as well as a 12 volt one. My opinion is that most people change to 12 volts to: 1) Save money (they think) 2)to hide or correct some fault that could have been easily and simply corrected, and 3) because everybody else does it. Then when something breaks they whine. It never ceases to amaze me.....
trainv
11-18-2004 16:26:41
Hi all just converted my TO30 over to 12 volt WOW what a difference!!the whole project on took about 5 hrs including building 2 new brackets,had the battery which was same size as 6 volt and first time ever that i have seen the poor old amp meter work!! the ol' girl starts on the second crank and i beleive she even run a bit better she's happy i am happy TYs todd
David Crowe
11-18-2004 12:51:19
I agree that your starter was most likely near death anyway. I converted to 12V on my TO 30 eighteen years ago and only last year had to have it rebuilt due to wear. No damage due to the 12 volts at all.
James, UK
11-18-2004 00:35:02
Here in the UK a lot of the old 6V systems have been modified to 12V - purely and simply because over here 6V batteries are pretty expensive.
In the generations that this has been going on, there have been no reported issues around the practice.
It is likely your old 6V system would have done in the starter as well given time.
Jerry/MT
11-17-2004 18:56:48
I have had a six volt starter running with a 12 V system for over 10 years and have had no problems with the starter. The duty cycle on the starter is actually reduced since the current is halved at 12 V relative to 6 V. Your starter was probably plum wore out.
Mike Mohrhauser
11-17-2004 16:52:22
That doesn't surprise me. I just bought a TO20 that has been converted to 12v. It really hammers the starter when you sing 12v's at a 6v starter.I'd guess that if it doesn't take my starter out the ring gear may lose some teeth. If someone wants to trade their 6v TO20 generator for my 12v set-up I would gladdly trade.
Mike M.
tractorfix
11-17-2004 14:05:24
It was likely on its last legs to start with. This is usually not a problem so long as restraint is practiced with the switch. Excess cranking will melt them. If you actually broke something, I would consider it freakish and forget it. You should hear the one on Dad's 49 Plymouth. It cranks it faster than it will run!
