Pinning
Mark Maynard
11-16-2004 13:38:35
I was woundering. I have a TO-30 with a cracked block. I have heard that you can pin the engine. But I have yet to find any information about this procedure. Could someone please help with my need for this infromation.
Jerry/MT
11-17-2004 13:10:47
 Re: Pinning in reply to Mark Maynard, 11-16-2004 13:38:35
A better way to repair the block is via furnace brazing. It's an aerospace developed technique that is in widespread use and is superior to the old pinning or the tension rod methods utilized on the older TO's. I bought a remanufactured Z-129 ( to replace my old cracked and wore out Z129 which had tension rods holding the cracks shut) and it had been repaired using the furnace brazing technique and have been very happy with the result. I have seen it used ona Case backhoe engine with equally good results.
Mr Chapp
11-17-2004 05:05:26
Hi Mark. By all means take Paul up on his offer. Cast iron repair is becoming a lost art. Pinning is done by finding the true end of the crack, drilling holes at each end of the crack, and swedging pins in the holes to"stop the crack" from continuing during the welding process. This an over simplification but will help you understand. Good luck...Mike
Paul in AZ
11-16-2004 17:44:34
Mark, if you will e-mail me at pnelson239(at)earthlink(dot)net I will e-mail you back with the phone number of an individual who does repair of Continental blocks with pinning.
