tea hydralic ports
Ian A.
11-15-2004 18:37:20
third party image
looking at other tea-20s they all have the two ports on the lift cover but mine doesent it has a port coming out of the bottom plate from the pump its a banjo bolt and has a square head plug on it could this be from another tractor.
another questions is that my tractor has a 12 volt system that has a original 12 volt starter and generator and my serial is tea-1900?? and i read someweare that the 12 volt system wasent till after 200000
there is a picture of the tractor included
Ian A.
11-17-2004 18:08:19
 Re: tea hydralic ports in reply to Ian A., 11-15-2004 18:37:20
that is my step father on ther tractor at the time and that is my nice i took the starter off today and noticed it is a newer starter because the holes were farther out and someone drilled new holes and tapped them but the genorator is original i have never tested it for output and the whole serial number is tea190038 i recently replaced the lift cover gasket and the whole thing was painted that odd orange colorsame as inside the rear end. when i had the started out i checked the timing with the hole in the bell housing and the distributor was off 90 degrees and now i gotta get new plugs becuse the disributor being off fould the plugs so bad that they dont fire
John (UK)
11-20-2004 08:54:42
 Re: tea hydralic ports in reply to Ian A., 11-17-2004 18:08:19
If the Lift Cover is painted that orange colour it has been changed it is NOT the original
gshadel
11-17-2004 12:50:21
I actually don't know anything about TEA's, but I gotta say, looks like your rais'in that young'n right! I gotta get my youngsters started on my TO too.
Looks like a bunch of work went into that impressive row of stacked wood back there, that will keep you warm this Winter.
John (UK)
11-17-2004 12:22:28
Those tapping off points on the lift cover were introduced at tractor # 200,001 (1951)same time as the 12v electrics. The blanking plug on the hydraulic pump should be a hexagon so possibly that plug in yours has been fitted because they dont have an original...whats the betting it is the wrong thread too?? It could just be one they used on a loader at some time, there were some like that.You say that it has a 12v starter, is it the correct long nose starter that was fitted after 200,001 in production or is it an oddball short nose 12v starter that just happens to fit.
James, UK
11-18-2004 13:29:10
 Re: tea hydralic ports in reply to John (UK), 11-17-2004 12:22:28
John, just went and checked mine after reading your post, mine is a '51 TED, and is fitted with the tap off points on the cover. Yet it would be early for your serial number for the changeover - none of the history I have indicates any such change to have been made after purchase, so my conclusion is that the 200,000 mark is a rule of thumb depending on type??
Not questioning your reply/knowledge, just adding to the info.
Good to see you back, noticed you dropped out of sight again for a while.
John (UK)
11-18-2004 13:56:46
 Re: tea hydralic ports in reply to James, UK, 11-18-2004 13:29:10
Hi James, Checked the manual again and the information is they were changed at 200,001 and that was produced in 1951. The serial numbers all ran together just the prefix was changed depending on the engine. I must admit that I have always taken it that the change-over point was 200,001 because a few modifications were done at that point including the big one...changing to 12v so I dont know how you come to have one that is modified prior to that serial number unless the Ferguson archive machine has gone haywire. What is your serial number and is it 6v or 12v? I am like a bad penny James...I just keep turning up.
James, UK
11-19-2004 09:55:31
 Re: tea hydralic ports in reply to John (UK), 11-18-2004 13:56:46
As per my message above, serial #182266, 1st registered 6th April 1951 to the Countess of Midleton, Eastwell Park, Kent.
Been through 6 owners prior to me, was 6V when I got her, is now 12V (but still have the bits in the garage JIC). All seems original, and nothing to indicate any mods over the years.
I have been told before that the changeover and intro of new parts etc. was a bit haphazard, but my ser# is still 17000+ off the 200k one you mention. Just puzzled is all. Maybe I should just accept it as one of life's big mysteries.
John (UK)
11-19-2004 11:31:25
 Re: tea hydralic ports in reply to James, UK, 11-19-2004 09:55:31
Thanks for that James...it is a lot of numbers off 200,001.but I dont think they would be so far out. I would think that it has been changed at sometime because they did modify a lot and with the tractor being so old its possible that you can no longer tell. Just something I thought about..what are the casting dates on the transmission housing they may give us some clue. BTW are you claiming that your tractor is some sort of aristocracy or something????? They used to send out service bulletins regarding any special items they were testing or anything that was modified and I am pretty sure they would not let something like the Hydraulic Cover go without something being said.
James, UK
11-20-2004 03:13:34
 Re: tea hydralic ports in reply to John (UK), 11-19-2004 11:31:25
Thanks for that - I'll have a look at the casting numbers when I get a chance. No the tractor isn't aristocracy, but the first owner was - she was an actress named Renee Ray, and became the Countess of Midleton when she married the Count.
Eastwell Park is now Eastwell Manor Hotel, and the Countess retired to Guernsey after her husband died in the 70s(?). She died a few years ago. It would have been nice to have 'reunited' the tractor and first owner, but never mind. They had no children so the trail is cold.
TTFN
James, UK
11-17-2004 08:42:17
OK I'll have a go at this. There may be two ports on the plate under the tractor, where the hydraulic pump is mounted - my TED has a similar configuration to your description. This is normal, at least for the earlier ones, mine being 6V #182266, just at the point 12V came in.
One port points rearwards from the bottom plate from the LHS (for the trailer pipe) the other point forwards, from the bottom RHS when viewed sitting in the seat.
It is really unlikely a lump from another tractor would be a straight fit. (unless its from an 'N' Ford??)
There is nothing to say yours hasn't had an engine transplant from a later engined model at some time in its life, so it may look entirely original, but not be.
HTH
