hyd pump
Dennis Glona Sr
11-14-2004 08:07:12
T0-30 roughly about 10 psi on hyd,use pressure test screw in right side of tranny,hyd wont lift, where should I start to check, T03551 inherited from my father,with a 2-blade disk plow,rework front axel center pivot bearing,install needle bearing housing,also info to install a hyd pump on front end for new style front end loader,any info will be helpful,,Thanks
John (UK)
11-14-2004 12:34:48
 Re: hyd pump in reply to Dennis Glona Sr, 11-14-2004 08:07:12
Mail me and I will send you a "How-to" check sheet for this hydraulic system, what to do and where to start. Just one thing...are you trying to check the pressure without fastening the link arms down so they wont rise to the top? If you don't it will shut the hydraulic pressure off. Mail me at....fergusontractors at hotmail dot com
