engine fouling plugs fast then running BAD
Ian A.
11-13-2004 17:33:07
i have a TEA-20 1951 and when i put plugs in in it it fouls them out on the first crank then its running on only two cylinders is there a way to stop this from happening could it be the carb becaude its carbon foul but wouldnt that be all plugs and its the same plugs every time 2-3
And john(uk) coul you send me the directions to adjustin the big spring on the 3 pt hitch because my blade bounces when it is all the way up
Ian A.
11-18-2004 17:54:20
 Re: engine fouling plugs fast then running BAD in reply to Ian A., 11-13-2004 17:33:07
just looked at timming and the disributor was 90 degrees off just gotta get new plugs because old ones just wont fire i tries the wire strait to the metal and it was a strong bluish white spark
Ian A.
11-14-2004 18:56:06
john (uk) my e-mail adress is [email protected]
send me the spec sheet and the ajustment sheet also and to tractorfix i dont have the equipment to do a compression test
and to jerry/mt the deposits are fluffy on the insulator and wet on the electrode its kinda strange
John (UK)
11-14-2004 13:01:13
The plugs in this engine were Champion L10 set to .030" but any equivalent plug will be ok. Check the engine timing isnt retarded I have had that same thing in the past.Check the timing and if you need the correct spec let me know. I need your email address so I can send you the instructions for the hydraulics fergusontractors at hotmail dot com
tractorfix
11-14-2004 05:19:20
You need to check your firing order. You need to check for carbon tracking on the cap. You need to do a compression test. A carburetor problem will not foul only 2 cyls. It would foul them all. Let us know what you find out!
Jerry/MT
11-13-2004 18:38:52
What does the fouling look like? It is wet, black, and oily looking? If so it could be your oil control rings are bad. If its black fluffy deposits, it's carb running too rich, but why on only #2 & #3? Intake manifold leak on #1 & #4? Are you sure that your wires are hooked up right?
