Carburator Identification
Wesley Foley
11-11-2004 19:32:16
I have a TO 20 that is in need of carburetor rebuild kit. I"ve looked on the carburetor and don"t seem to see any type of identification other that what appears to be a few "8""s in various spots. It"s a heavy, cast type. Are there suposed to be numbers and manufacturer"s names on these or some reference someplace that I could determine what I have? Thanks in advance.
Sodbuster
11-13-2004 04:18:38
 Re: Carburator Identification in reply to Wesley Foley, 11-11-2004 19:32:16
gshadel is correct. The TSX361A was used on the TO-20 and the TE-20. Good luck..... ..... ..
gshadel
11-12-2004 05:50:50
Wes, if you have an original carb, it is probably a Marvel Schebler model TSX361A. It should have Marvel Schebler in raised letters right in the casting. These carbs also had a brass tag stamped on the side with the model# stamped on it. It is possible that tag is gone, but might be crudded-up too. As your are looking at the carb on the tractor, the name and model# on the carb should be facing towards you. Might need to clean'er up real good to find this, the print is kind-of small. If you have a replacement carb, it could be a Marvel, or a Zenith carb... I don't know much about Zenith carbs.
The carb rebuild kits work on a lot of similar carbs, chances are, you get a TO-20 carb rebuild kit, it will work just fine for you.
Good Luck
