Are the headlights on Ferg. 20 same as 2N and 9N?
Wayne Wiseman
11-05-2004 05:41:56
Just purchased a Ferg. TO20. The back work light is missing. Want to keep the back work light the same as the front lights. Are the headlights on a 2N/9N same as the Ferg. TO20? If not, any idea where I can purchased the back light?
pjfenner
11-07-2004 23:11:09
 Re: Are the headlights on Ferg. 20 same as 2N and in reply to Wayne Wiseman, 11-05-2004 05:41:56
Wayne, original backlights or front lights for that matter are only found in salvage as far as I know. As Paul mentioned, the size is different from Ford and the bezel uses two screws to fasten it to the housing as opposed to the ring clamp that Ford used.
Phil(WA)
Wayne Wiseman
11-09-2004 18:23:37
 Re: Are the headlights on Ferg. 20 same as 2N and in reply to pjfenner, 11-07-2004 23:11:09
Thanks for your input. I will start looking for only the Ferguson lights.
Paul in Az
11-07-2004 16:40:38
No, they are slightly larger in diameter than the Ford units. Both, however, were made by Hall.
