Spark
Jim Hanton
11-03-2004 09:43:27
Hello all. My TED-20 has been starting fine up until recently. It had been sitting out in really wet weather so the other day I thought I better check that it was working alright. So I went out and of course my fears came true, it didn't start. I had the distributor and coil off the other week for painting the engine block and I have checked they are secured properly. The spark plugs are not sparking but the condenser, points, plugs and HT leads were replced earlier this year. Any ideas as to what's gone wrong?
Thanks in advance
Jim Hanton
John (UK)
11-03-2004 13:13:26
 Re: Spark in reply to Jim Hanton, 11-03-2004 09:43:27
Check all the connections again, make sure points gap is set .012" Change condenser if still no spark. Check low tension lead through distributor body, is the insulating bush damaged. It is wet inside distributor cap.
Jim Hanton
11-03-2004 23:52:02
 Re: Spark in reply to John (UK), 11-03-2004 13:13:26
Thanks John. I'll have a look at the tractor tonight when I get in from work.
Cheers
Jim Hanton
