got taken!!
james in ca.
11-02-2004 19:25:45
Well the 3 point started acting funny so i check the fluid and its low so i add some, well not long after it starts acting up again and its low on fluid with no visable leaks, except now the clutch is grabbing bad, see where this is leading? I pulled the clutch cover only to have 2 or 3 quarts come pouring out!!! and i found a cork stuck in the weep hole! So to make it short i now need a new clutch and have the seal replaced. the local dealer quoted me 800 in parts and 800 labor! does that sound right? Its a f40
gshadel
11-04-2004 06:07:04
 Re: got taken!! in reply to james in ca., 11-02-2004 19:25:45
James, labor might be higher in Ca. than around here, or they might be charging you for work you don't need. The parts shouldn't cost near that much unless they are replacing the flywheel and everything else between the engine and tranny.
I'm guessing you need a new clutch disc, tranny seal, and a cotter pin for the weep hole. That's like ~$150 max. Check out the parts link on this page for prices, I was just looking at them.
I don't know anything about the duel clutch on a F40, but if it is anywhere near as easy to work on as my TO-20, you might want to consider doing the job yourself. Just need regular hand tools, and a guide to line-up the clutch splines, which costs ~$5 at a parts store. Need a couple good jacks when you split the tractor. I used a rolling car jack under the engine so I could pull the engine away from the tranny, worked great.
Think of all the money you will save, and sounds like a good excuse to buy a few new tools.
Good luck!
james in ca.
11-04-2004 19:27:22
 Re: got taken!! in reply to gshadel, 11-04-2004 06:07:04
Thanks for the comments guys, After talking to some tractor buddies i am convinced to just do it myself after all. I think the guy just quoted me a worst case as he didnt even know what an f40 was till i told him they became the 50 later on. by the way how did you find the right pilot tool, cause i know the guys around here will just give me a blank stare when i tell them what its for.
Jerry/MT
11-05-2004 16:55:21
 Re: got taken!! in reply to james in ca., 11-04-2004 19:27:22
Try Harbor Freight Tools. I bought a set of clutch pilots for under $10 and right now the mice are playing with them because I think I'm a long ways away from a clutch replacement.
Gerald J.
11-04-2004 21:07:30
 Re: pilot in reply to james in ca., 11-04-2004 19:27:22
Take the new clutch plate to the parts store with pilots. But first determine the pilot bearing size from measuring the bearing or the pilot end of the transmission shaft. Then ask for a clutch plate alignment tool for a (say) 1/2" pilot bearing and this clutch plate. They should be able to fit it that way. I have a metal lathe and so the last time I needed that tool I turned a piece of dowel to fit the inside of the splines on the clutch plate, but I didn't know the pilot bearing size, so I just turned a cone. Worked fine. I've been successful at times just centering the clutch plate splines around the pilot bearing by eye.
Gerald J.
james in ca.
11-04-2004 21:37:11
 Re: pilot in reply to Gerald J., 11-04-2004 21:07:30
Thanks Gerald, I hav also put them in cars by eye then had someone push in on clutch pedal while i would push and rock trans.
Gregg/Ohio
11-02-2004 21:13:27
"the local dealer quoted me 800 in parts and 800 labor! does that sound right? Its a f40."
The labor they charge around here for that job is around 650.00, I really dont know what parts you would need,(total) but I can not for the life of me,how it could be more then 400.00 dollars,for the parts.
