Radiator Replacement TO-30
Ralph_Mich
10-28-2004 11:06:26
Has anyone had a problem with replacement radiators? Replacements neck has more a downward angle, does not line up with water pumps and interferes with support rod. Original shroud is close to upper inlet hose .Can I run without the shroud? Replacement radiator made in Turkey go figure
martin christian
10-28-2004 16:48:32
 Re: Radiator Replacement TO-30 in reply to Ralph_Mich, 10-28-2004 11:06:26
I bought one for my TO-30 from this site fit like a glove TractorRadiators.com Catalog
Main Entrance | View Shopping Cart | Place Order | Help
Allis Chalmers | Case/DavidBrown | Ford | International Harvester | John Deere | Massey Ferguson
Massey Ferguson Part 181623M1/3900 - MF RADIATOR
Radiator for MF tractors: TEA 20, TO 20, TO 30. Core size: 15.062" wide, 17.312" high, 3 rows of tubes, 5 fins per inch. Price: $148.00 Enter quantity to cart
John (UK)
10-28-2004 11:29:06
The shroud or cowling was fitted to make the fan more efficient and cool it better, its better with the cowling.
Ralph-Mich
10-28-2004 13:42:45
 Re: Radiator Replacement TO-30 in reply to John (UK), 10-28-2004 11:29:06
John I assume it would get a greater cooling with shroud. The only way I could use the replacement radiator,with original shroud would be to us a 6" flexable upper hose. (With out thermostat) and fabricating a new support rod which would be longer. Rod would have to be straight under tool tray than 45 degrees up to catch ,radiator support tab. Whats your opinion ? P.S. replacement rad 145$ US to a recore of 375$ on my original Thanks John
John (UK)
10-28-2004 13:57:50
 Re: Radiator Replacement TO-30 in reply to Ralph-Mich, 10-28-2004 13:42:45
You would get greater cooling with the shroud that is why they fit it.If you have to run without a thermostat the engine will never get warm and soon wear out. I think it would cost a great deal more in the long run by using the cheaper radiator, but I can see where you are coming from on that. Seems an awful lot for a recore, have you tried around others. Seems more like the price of a new one to me but I may be getting confused because the price is dollars and I am used to pounds. I should wait and see what the other guys on here can find for you before you do aything I am sure they will point you in the right direction.
