TO35 Ferguson-Changing 12V Generator to 12V Altern
Frank E. Ritter
10-27-2004 17:48:24
Changing 12v generator and regulator with new 12v alternator with build-in regulator. Need new electric wiring diagram for tractor. Thanks
Paul in AZ
11-01-2004 05:33:28
 Re: TO35 Ferguson-Changing 12V Generator to 12V Al in reply to Frank E. Rittershofer, 10-27-2004 17:48:24
Frank, I'm at earthlink(dol).net. Sorry, I gave you the wrong information earlier.
Paul
Daniel H.
10-28-2004 18:42:51
Are you giving up your tach drive to install the alternator or do you not have a tach?
Here is a diagram for a Farmall, but it is using a GM alternator so it will be the same. You can replace the lightbulb with a diode from Radio Shack if you dont want the charge light but you CANNOT simply leave it out. If it is omitted the alternator will not charge, if you just use a wire the tractor will not cut off.
Good Luck
Paul in AZ
10-28-2004 08:29:23
Frank, would you please contact me about your generator at pnelson239(at)earthlink(dot).com?
Thanks!
