tractormeter
james in ca
10-23-2004 17:27:47
Hello, i have what i think is a to35. I say "THINK" because the sheetmetal looks like an f40 but the serial plate that was screwed to the dash not riveted on says 14088. I did find a # on the steering box 145581. Well my question is the speedo cable was just hanging loose and i cant find a spot where it goes in so i can watchmt rpm's. Any help would be appreciated.
Dean Baileys
10-23-2004 18:12:04
 Re: tractormeter in reply to james in ca, 10-23-2004 17:27:47
The cable screws into the generator rear end housing. I think probably the previous owner has replaced the generator with one that doesn't have the drive unit. You would have seen where it goes if it were there. I had the opposite problem with my to35, no cable.
james in ca.
10-23-2004 20:25:07
 Re: tractormeter in reply to Dean Baileys, 10-23-2004 18:12:04
Thanks Dean that explains it cause someone put on an altenater sp? with a mf part # on it. should i go back to a gen or is there a later meter i could use? thanks.
