Woops new tires TO30 will not plow
john cunningham
10-22-2004 03:49:04
I have a new set of 12.4 x 28 as replacements to the original. I was happy with them until last night. I was fall plowing the garden and noticed the plow would not go in as deep as last year. I let some of the air out of the tires and it plowed better. Oh yes I am using a Ford 2 bottom plow. I see no adustments I can make. The top link may be too long. I want to plow at least 8" deep. I guess I could get another ajustable lift arm.
Gene Stevens
10-23-2004 07:15:00
 Re: Woops new tires TO30 will not plow in reply to john cunningham, 10-22-2004 03:49:04
Place a six inch block under the left rear wheel. Lower the plow until the tips touch the ground. Adjust them up or down as needed so both just touch. Then turn the upper link so the set flat on the ground. Run a string along the backside to the front of the tractor. It should be approximatly 3-6 inches to the right of center. Then make any minor adjustments in the field. Gene
sawtooth
10-23-2004 06:11:33
I just plowed our garden with a TO 30 a couple days ago. Years ago dad made a cement weight that he bolted on to the top of the plow, I'd guess it weighs at least 200 pounds. In some conditions the plow isn't heavy enough to penetrate. More weight helps. You could try wheel weights.
John (UK)
10-24-2004 06:22:12
 Re: Woops new tires TO30 will not plow in reply to sawtooth, 10-23-2004 06:11:33
When the plough wont pull into the ground it's either the top link too long (so the plough runs nose up) or the plough shares are worn and the point or "Suck" is worn away. All those ploughs have a special type of share fitted so it will pull into the ground, you should not have a flat share underneath, just behind the actual point there will be a gap between the ground and the underneath of the share, if there is no gap there is no "Suck" so it can't pull itself into the ground. Looking at the share, side on you, should see a positive curve going downwards towards the point.
Boss Hog
10-22-2004 06:02:16
Sounds to me like you need to adjust your top link length.
(Try saying that 3 times real fast)
John Cunningham
10-22-2004 14:52:16
 Re: Woops new tires TO30 will not plow in reply to Boss Hog, 10-22-2004 06:02:16
I assume you mean it is too long. It is hard to say. Thanks Boss
Boss Hog
10-23-2004 05:29:52
 Re: Woops new tires TO30 will not plow in reply to John Cunningham, 10-22-2004 14:52:16
You're correct that I was thinking the top link might need to be shortened.
I like to use a threaded adjustable top link when I'm plowing, so I can play with it and make fine adjustments until I get it to where it suits me.
