TO 30 Hand Crank Specs
Mick
10-21-2004 07:21:48
Does anyone have the specs/pictures for a TO 30 hand crank? I've searched the archives the internet, and eBay, but can find nothing specific. I, of course, can measure the main dimensions, but I'm not certain of diameters, crank pin placement, etc. A friend has offered to build an exact match if I can get him the info. Thanks.
kesiladi
10-22-2004 17:11:28
 Re: TO 30 Hand Crank Specs in reply to Mick, 10-21-2004 07:21:48
I know I saw the specs in the archive one time because I have one half made. I used a piece of 3/4 inch smooth steel rod 3 feet long (common hardware store item). Also you will need a 5/16 x 1 1/4 inch roll pin (a solid pin would be better). Drill a 5/16 diameter hole in the rod so that the back edge of the pin is 1 inch from the end of the rod. That would make the center of the hole 27/32 inch from the end of the rod. What I don't know is where the bend starts and how long to make it. Obviously, if you insert the rod with the pin through the grill all the way into the engine one can get a good idea of where the bend needs to begin. I just don't know how much offset is there should be. Hope this helps and good luck !
Mick
10-23-2004 11:48:27
 Re: TO 30 Hand Crank Specs in reply to kesiladi, 10-22-2004 17:11:28
Thanks. A friend of mine who is a high school shop teacher said he thought he could make one if I could get him some basic measurements to get him started. Thanks for this info.
Roman Nose
10-21-2004 12:04:14
I have one I can sell you or I can take pictures if that is all you need.
Mick
10-21-2004 17:04:37
 Re: TO 30 Hand Crank Specs in reply to Roman Nose, 10-21-2004 12:04:14
I appreciate it, and may take you up on it if I can't get one made. It's a high school shop project. How much are you asking for the crank you have?
