MASSEY FERGUSON TO - 35 Z134 TIMING
RANDY MAYTON
10-20-2004 10:53:32
I AM REBUILDING A MASSEY FERGUSON TO-35, Z-134 CONTENTIAL GAS ENGINE, WHEN THE CRANKSHAFT AND CAMSHAFT TIMING MARKS ARE IN REGISTER IS NUMBER 1 OR NUMBER 4 CYLINDER SUPPOSE TO BE TOP DEAD CENTER ON COMPRESSION STROKE? MINE IS NUMBER 4 TOP DEAD CENTER ON COMPRESSION STROKE.
PLEASE ADVISE
George in Mi
10-22-2004 18:13:54
 Re: MASSEY FERGUSON TO - 35 Z134 TIMING in reply to RANDY MAYTON, 10-20-2004 10:53:32
According to my IT manual, the Z-134 should be static timed to 6 degrees before TDC with the number one piston up, ie, 6 degrees in advance.
At 2000 RPM spark should occur between 26-30 degrees for engines with the 1112557 distributer, for engines with the 1112570 distributor spark should occure betwen 28-32 degrees, at 2200 rpm. Neither of these is for the 8:1 comp. high altitude engine.
Good Luck,
GH
