Torque head bolts/nuts
Steve In Mo
10-19-2004 10:46:47
I have a 1950 To-20 pulled the head this wk end. Cycs and pistons look good so I will just have the head done. Question is this on the left side the nuts to hold the head, how do I torque them? Can't get the socket and wrench on them no room. Is a claw foot or a swivel better?
Jerry Doyon
10-27-2004 15:28:29
 Re: Torque head bolts/nuts in reply to Steve In Mo, 10-19-2004 10:46:47
I just re-torqued my head bolts a couple weeks ago when I had to adjust my valves. I used a special 6-point Crowfoot that can be purchased from Snap-on. They look like a flare nut wrench which folks normally use on brake lines. Mine was 3/8 square drive so I had to use an adaptor for my 1/2 dr. torque wrench. A regular crowfoot would just spring open under too much torque.
The U-shaped wrenches that Big Dean discribed sound like Aircraft cylinder head bolt wrenches that are common on general aviation planes. (I used to be an aircraft mechanic) These can usually be purchased by aviation tools supply houses... I think one of them was ATS?
Big Dean
10-19-2004 17:23:31
They make a kind of U shaped wrench that has a box end on the bottom and on the top it has a 1/2 square exactly over the bolt for the torque wrench. It is long enough for the top to be just above the head it is made to torque those bolts that does not have the room for a socket. I have 3 of them in my tool box a 5/8 a 7/17 & a 1/2. I have had them for about 25 years but can't remember were I got them I think though they are Snap-On.
gshadel
10-19-2004 14:52:03
This may not be real scientific, but when I torque down my head, I use a box wrench on those bolts. Might be able to get a claw foot on those nuts, but my recollection was only my box wrench was skinny enough to get those guys.
I feel how much pressure is needed with my wrench to move a nut that I just torqued with my fancy torque wrench, then guess-timate the torque with a "calibrated lean" on the wrench for those nuts on that left side of the head.
I've done that twice now, both times had no problems.
Make sure you follow the torque sequence in the book, and torque down the head in increments, not the full torque in one pass, and you should be fine
Good Luck!
